Hi,
after repairing the new software (installing from start) when booted to the main screen, it shows an option: You can not start using the software until you do a Video Test.
I dont have any device access codes, nor dont see an option for video test.
Please help!
Thanks in advance
Thu Jan 30 2020
Problem after software repair, Shows Video Test
Tue Feb 04 2020Reply from IAmShawky
hello , I believe that the "drivers CD" the last CD version is not compatable with the HW version of drivers in the CPU , what is the version of ultrasound app and does this HD7 is HD7XE ?
Ahmed Shawky
Ultrasound Field Service Engineer
bambav.medical@gmail.com
Bambav Medical
Wed Aug 31 2022Reply from McMillanbrom3
Hi, I just came across a thread discussing a problem with the setup after a reboot. https://www.medwrench.com/thread/210401/console-set-up-video-for-eviva in this topic you will learn how to properly reconfigure the program.
By the way, as far as I know, this tutorial video was edited with the help of this site, because the transition between frames is made smoothly and without jerks. I hope I helped solve your problem.
Mon Nov 21 2022Reply from GIDDYLEJO
Hello Ardi
Did you get access codes for this machine? I'm dealing with a similar problem on HD 7 XE at the moment.
