How to disassemble
RE: Bed Report Post
Please contact Hill-Rom Technical Support for Troubleshooting
technical.support@hill-rom.com
1-800-445-3720
8am-6:30pm EST (Monday – Thursday)
8am-6pm EST (Friday)
Thank you!
email me: mandy@medwrench.com
Connect with MedWrench:
I believe we've been through this recently. It depends on how skilled you are. MEdical devices, including hospital beds are not designed nor built to be easily disassembled and reassembled.
1st question would be, Are you sure the floor of the room you wish to use this device in, can support the bed? it weighs a lot more than a normal bed.
2nd question, do you own the bed or is it a rental?
You're going to need a few people to haul this bed through the doorway and up to the room you want it in.
I can't give you exact instructions on how to do this, just general and am i no way accepting any liablilty for what you do
raise the bed to max height to get access and maximum visibility, unplug from wall. Removed base covers and disconnect batteries if it has any. Engage each function to help drain any power form caps and such.
label each cable and it's connection before disconnecting
disconnect any cable connecting hte top half to the bottom half.
find a way to support the top half, then disconnect any hardware joining the 2 halves
now you can seperate the 2 halves. This should be enough to get the unit through the doorways. good luck
This bed has hydraulics for all of the mechanisms, so if you are not familiar with hydraulic systems I would advise against taking apart.
