I have an ilipo laser lipo from chromogenex. It worked well then suddenly after 5 minutes when the pads are placed on the client, the laser de-activates and show F3. Ive checked the cables and its all in order. I found that its the heat of the laser that gets too hot then shut down after 5 minutes automatically. What can i do, because i cannot use it on my clients and loose business. Im urgently in need of assistance please.
Wed Mar 04 2020
F3 FAULT - LASER PAD GETS TOO HOT AND SHUTS DOWN AFTER 5 MINUTES
Sat Aug 15 2020Reply from Jerry_Cristian
You need change the diodes laser from pads. The high temperature is generated by low efficiency from the diodes and the temperature sensor placed in each pad read the value and send to control box. If high than pre-set limit, it will show F3 error.
Jerry Cristian Gandin
www.scintilum.com.br
jerrycristian@gmail.com
