Thu Apr 23 2020
Change the time?
How do you change the time on the unit if there is no clock error?
Thu Apr 23 2020Reply from ReNew14
With unit powered off, hold down the #5 soft key under display. Power on it should be in the time set mode. If it powers on in normal operation. You will have to remove battery, wait 15-30 seconds and try again.
