I have a Philips Epiq7 that powers on for about a second or two but then shuts back down. It then tries over and over to turn on only to turn itself off each time. Anyone ever have this issue? Thanks!
Thu Apr 30 2020
Philips EPIQ7 not booting up
Mon May 04 2020Reply from MarioLM
Hello, if the Epiq7 is similar to the Epiq5, try unplugging the 4 batteries on the back of the unit and power up with unit plugged into AC. If this works, you have a bad battery pack.
Fri Jun 26 2020Reply from BoscanR
That could be a proble, with the batteries or a software problem. Try unplugging the batteries, if the problem persist then is a software problem. You could install the software, but need a backup of the device.
Kind regards
boscanrolando@gmail.com
