Preventative Maintenance
RE: Washer/Decontaminator Report Post
You also need to replace the pvc filter. Clean the inline screens on water line screens on tubes entering the bottom left, clean probe compartment and clean and flush separate disinfectant tank (2x per year)
Does anyone have an alternative to the OEM on the main carbon filter replacement on the td -100?
Nothing here. The bigger problem for us is getting around the annual PM from the vendor. It requires time and temperature verification (if I recall correctly) for about $3000.
TJ Lobato | MedWrench Guru
It is $3800 now and had I not been lied to by CS Medical tech support before we purchased the device I would have pushed for a different vendor. I was told the annual maintenance was simple and could be handled by in-house biomed; perhaps he was referring to chapter 6 of the operator maintenance. Now that I know there is additional PM maintenance that they will not provide information for, I would of fought harder to select a different vendor than CS Medical.
