Our Stat Spin rocks / vibrates upon start up and at the end of cycle when balanced. I don't have another rotor to test with and was wondering if this was the issue ?
Thu Apr 30 2020
Stat Spin 4 rocks /vibrates
Wed May 06 2020Reply from rstopczynski_5658
Take the rotor out and look on the bottom for cracks. I just had one do this and that was the problem.
Wed May 06 2020Reply from TRS
Most likely has a cracked rotor. I would recommend inspection of the motor mount as well. Ozark Biomedical part number is 10238 for rotor. May want to check imbalance switch adjustment additionally.
