Does not stay on user 1
We preset the machine to use all the settings we have built in user 1. For some reason it reverts back to factory default in user presets more when the machine is powered down. It has happened when we switch probes or end patient studies. Need to try CTRL +S next. It should still stay on factory presets when saved under preset. This messes up our measurements when it is not on user 1 as well. Thank you your help.
Lisa Bachan BA RDMS RDCS RVT RT (R) CITI (GCP)
Applications Specialist
Ultra Select Medical
GE Voluson E6
You can communicate with me here about my issue.
