Philips C arm BV 25 1993 is not giving an image
Have you checked the monitor...also is posible a problem in the video cable or in the TV camera..or in the image intesifying
Dear Ricarsc2 Greetings
-The TV camera is powered ON, and the small led in the back tube is lighting.
-How could I check the image intesifying ? is there any troubleshoot I should follow?
Ifyou live the camara from the intesifier can you get ambient image in the monitor?with the camera lived from the intensifier,if you lock in the window of the intensifier can you lok at the moment to do x ray exposicion a ligt green
Use a mirror yo see image at the imagen intesifier ( I I). Remenber you aré workin with x Ray .. good luck !!
If you have image in the intensifier and you have x ray,and if you have the same problem in fluororscopy mode as in radiographic mode,the problem will be in video circuit ..monitor or camera are defective,have you checked if you have ambient image in the monitor with the camere lived out of image intensifier and enfoqued to a light???
