hey, guys . on the pulsera i'm getting error code M211 camera iris positioning error. i open up the ii and check if, was lose or anything out of place . i couldn't find any thing. can anybody help me.? tell me what to look for? how to solve this problem.. thank you
M211 error code
Iris Is placed at side of x Ray tube, not in I I side... AND It Is a part of collimator, so unmount collimator AND CHECK visually all you can .... Be careful !!!
When C arm Is swit ched on, collimator open AND close AND iris also Is moving... All moving parts inside collimator aré motorized... Pay attention to collimator operation ....
I did you said and everything seems fine. The only problem is when you shoot a x-ray the picture is reverse.
Checa buttons at consolé, one Is to Reverse image upside down AND other allows letf - right Reverse
Check user manual.!!!!
yeah, checked the butons ,it dosent reverse the way it should e. example is if you take a x-ray with your left hand, palms down, the image will show like you took the picture palms up. if you press the reverse button will just flip the image.(fingers where the wrist is). also, the m211 error is still there. thanks again
Un 3 or 4 days i Will be at home, THEN i Will try to check my mAnuals yo see for error M 211.
In the meantime ...
First of all, it is worthy to mention that there is an IRIS in the collimator (tube side), and there is an IRIS in the camera side.
In your case, the error is in the camera IRIS.
(From manual, M211: The XTV diaphragm is not ready. Perform dose calibration.
Check cable Check power supply to the XTV).
So you need to check the flat cable, II power supply. If you get an image on the monitor, when you press H/S, so it is worthy to perform dose calibration (using service PC, of course). Lastly, you should think about replacing II.
So you need to check the flat cable, II power supply. If you get an image on the monitor, when you press H/S, so it is worthy to perform dose calibration (using service PC, of course). Lastly, you should think about replacing camera.
