i am having trouble getting the door to open on the machine (getinge vacuum/gravity steam sterilizer 733hc) in SPD please help
Mon Jun 08 2020
door will not open
Tue Jun 09 2020Reply from Chris35
Try turning the steam supply off, wait for it to cool, then press unseal / open door. Your steam to door gasket valve may be leaking by and not allowing the gasket to retract.
Thu Jun 25 2020Reply from xxix
gasket need to be replaced every 6 months.
it could very well be a bad gasket.
getinge field tech gave a troubleshooting tip:
"bump your body against the door to help release it as you press door open"
resolution is change the gasket.
