The system is showing a failed to connect to recon restart the console software at application software startup.
Restarting the console software is not solving the problem. What could be the problem and where should i start from checking this error?
Fri Jun 12 2020
Recon connection error
Fri Jun 12 2020Reply from Ben C
Tue Jun 16 2020Reply from Service Mammo
Tue Jun 16 2020Reply from Ben C
