Epiq 7cv freezing
That could be 3 things, 1.- A database corrupted. 2.- A problem with the hard disk. or 3.- A software problem. With the first tou could erase the patien database and the device couls start normally. For the 2 and 3 need to reload the software.
Kind regards
boscanrolando@gmail.com
Hi, im also experience the same DiagCode: 207 after i replace the both patient data hardisk. Using same specification, same brand but different model hardisk. after reload software plug in X5-1 or X7-2 will pop-up error 207. use back the original problem hardisk no problem at all.
That sounds like a problem in the Adquisition Front.
Kind regards
I put back the original hardisk which i had scanned got error and reload software. Put in X5-1 & X7-2 transducer had no error 207. Wondering if the new hardisk issues?
