How do I replace bulb in my unico m250fl microscope? Is there an owners manual I can download???
Sat Jun 27 2020
Bulb replacement
Sun Jul 05 2020Reply from Microscope Recovery
There is an access door on the bottom of the microscope.
1.Unplug the microscope from its power source
2. lay the microscope on its side.
3. Pull the tab or unscrew the access door retaining screw.
4. The bulb is a 6v 20w two pin bulb an can be pulled out of the lamp socket.
5. Replace with a 64250 6v 20w bulb. Do not touch the new bulb with your bare fingers. The oil from your skin will cause short bulb life.
6. Close and fasten the access door
7. place the microscope on its feet. Plug in the microscope and turn on the power switch.
Justin
Microscope Recovery
