Wed Jul 01 2020
Connectivity
I need to integrate GE DASH 4000 monitors into my medical data network. 1 - Can I integrate without using Carescape through an API? 2 - Should I use direct serial cable or null modem and an RJ45 converter? (which part number or cable and converter pinout specification?) 3 - Would someone have the original format of the message sent by the monitor so that we can transform it into HL7 V2.x? Please, do any colleagues have tips or experience with this model? Thank you very much for any help ...
Thu Jul 02 2020Reply from MedWrench Kari
MedWrench Kari
USOC
Southeastern
Southwestern
Sage Services
BMES
GE
Kari Thompson | Data Entry Coordinator                     email me: kari@medwrench.com
Sun Jul 05 2020Reply from CMB7
CMB7
You should be able to find everything you need here:
https://www.banggood.com/RJ45-Ethernet-Male-to-8-Pin-AV-Terminal-Screw-Adapter-Converter-Block-CCTV-1PC-p-1077444.html?cur_warehouse=CN
I would hard-wire the units.
How many monitors will be in the network?
Regards, MIchel.
Servicios Tecnicos CMB7
535 Canteval Terrace,
Orleans, Ontario.
K4A 2E3
Mobile: 6138185321
Tue Jul 07 2020Reply from jroberts
jroberts
Hey radesPaulo.
Serial interface documentation per GE can be found here:
https://customer-doc.cloud.gehealthcare.com/#/cdp/dashboard
Search for the following string: 2001005-128
you can find ALL the Dash 4000 documentation but specifying the following in the drop-downs:
-J
