Hello I need some help,
I have been getting supply overtemp errors with some Quanta Thunders (Duetto's Successor). The problem occurs with the ALEX when the scanner attachment is attached (fast beats) and at 14 Hz (maximum).
Then a "supply overtemp" error shows up, after the laser has shot around 3000 beats.
First I replaced the thermo switch, which didn't solve the problem.
Then I replaced the flash lamp which improved the voltage, but the error still occurred, so I tried replacing the charger.
After all this, the error message still showed up. Can I get any advice on what to try next?
