Technical error - 25
Tue Jul 07 2020
Ventilator
Tue Jul 07 2020Reply from Ray Brown, CBET
Interesting. Internal communications error. You have to get into Service Mode and read the Technical Alarm Log to determine which board is the problem. There's over a dozen codes. If it's code 0, you have to call Maquet. If it's 512, most likely, it's a problem with the PC1777 inside the display.
