Good afternoon I have a problem electrocautery bovie maxxim x 30 there is no power output in coagulation I do not have a service manual can help me solve this problem
Sat Jul 11 2020
Mon Jul 13 2020Reply from T-Lobato
I would check both handcontrol switches but you have probably done that. Can you change the level using the up and down and arrows? Or does it indicate zero and cannot be changed? It's going to be tough without the manual but I would not rule out the obvious meaning look inside, check fuses, change the handpieces, etc.
Just me.
TJ Lobato | MedWrench Guru
