Good evening, I have a problem with the Stryker L9000 Light Source. When the light is activated, E2 appears on the display and the light that remains on for a few seconds and is blue. Can someone help me. Thanks so much.
Thu Jul 16 2020
Error E2
Thu Jul 16 2020Reply from T-Lobato
Mon Jul 27 2020Reply from Medina Gentry
If I recall correctly, with E2, you usually only have to open the unit and spray out all the dust build up. If that doesn't work and the bulb is still turning blue, you will need to change the bulb.
Wed May 17 2023Reply from Harnish Shah
