Fri Jul 17 2020
Ventilator Inoperative
Good Day! Hoping someone can help us with our problem. We have 2 units of PB840 and they're not working anymore. Unfortunately, we don't have a BioMed. Can someone please help us how to troubleshoot the ventilator. It appears "Ventilator inoperative". What does it mean? How to fix it? Thank you!
Fri Jul 17 2020Reply from T-Lobato
T-Lobato
Here's what the manual says, "In some situations, the ventilator declares a ventilator inoperative condition. A hardware failure or critical software error that could compromise safe ventilation triggers this condition. When this occurs, the ventilator inoperative indicator lights and the ventilator enters the safety valve open (SVO) state. To correct a ventilator inoperative condition, the ventilator must be turned off, then powered on again; at power on, a qualified service technician must run extended self test (EST). The ventilator must pass EST before normal ventilation can resume."
Not knowing where you're located, I would recommend calling a local hospital and talking with the Biomed department for possible service providers.  You could also call Medtronic and ask them for assistance.
Good luck!
TJ Lobato | MedWrench Guru
Sat Jul 18 2020Reply from NarsCCU
Thank you so much for your kind reply.
Unfortunately, our ventilator failed the EST more than 3 times. It used to work after a succesful EST whenever we use it. However this time, every after EST the ventilator flashes "ventilator inoperative".
I really appreciate your help, didn't expect you'd reply.
Godbless!
Isabela
Sat Jul 18 2020Reply from jrpiceno
Hi,
Are you using the correct test circuit? That is very important to have. I would take note of each test that failed in the EST and start there. If you can start the EST, I would say that is a good indication the communication between the GUI and BDU is ok. Has your unit been sitting for a while or in use? These have also reached the end of manufacturer support. You can still get parts from vendors like PartsSource if needed.
Hope this helps.
JP
Hello!
Thank you for replying. We're using Hudson ventilator circuit ever since. Our Ventilators are stocked for more than a month now. We tried everything we can--EST everyday, but the same result and it also shows OVERRIDEN. If you have some ideas or advices on how to troubleshoot our ventilators, we're willing to try it.
Thank you and God bless you!
Isabela
Tue Jul 21 2020Reply from Amscopolaris
Amscopolaris
Flex tube, 21.0 in. (53.4 cm) (gold standard tube) (2 required) 4-018506-00 EST, performance verification
if there is no tube in this feature, est test gives error
Tue Jul 21 2020Reply from CMB7
CMB7
Isabela
I am a RRT - you can email me with the following info please:
Please reply with all the information on the unit's ID tag:
  • Serial number -
  • Model number -
  • Year of manufacture -
PLUS
  • Software updates? Yes___ No___
  • Nature of the problems:
Regards, Michel.
Servicios Tecnicos CMB7
535 Canteval,
Ottawa, Canada
Mobile: 6138185321
Thu Jul 23 2020Reply from NarsCCU
Good Day Sir! I already sent you an email. Thank you!
Isabela
Fri Jul 24 2020Reply from NarsCCU
Hello Sir! Do you have another email? It says that the email address is not found. Thank you!
Isabela
Mon Jul 27 2020Reply from Manford
Hi Isabela,
Have you solved the PB840 problem on "ventilator inoperative"?
Doing an EST on 840 vent needs a "gold tube" without a inlet filter.  Some biomed make this mistake putting a filter on and not work.  Plus you must be trained on this vent.  Some hospital RRT run EST and some hospitals only allow biomed to do.
If you run a PVT, you need a PTS-2000 (calibration date not expired) plus two gold tubes plus a proper vent circuit and some accessory like 840vts vent software and plug...    You cannot do PVT without factory trained and equipment.  Ask Medtronic (previous Covidien) for help.
You question might be a very simple issue as I saw many times came in with this message.
Sincerely
MK
20 hours agoReply from CMB7
CMB7
Isabela, here is my contact info:
535 Canteval,
Ottawa, Canada
Mobile: 6138185321
