Ultrasound machine freezing
Hi, there are some known issues with this machine freezing up due to wireless network printer activity or a faulty touch screen, but the best way to find out is to have someone analyze the error logs and check for errors indicating a specific hardware or software problem. I have seen this issue be caused by several different components and/or multiple components.
if you use a wireless network printer, remove it from your system and try scanning again. If not, I would recommend having a trained field engineer take a look at it. Guesswork is expensive.
It wasn’t broken until I fixed it.
I recommend you to check for an update of the driver's and make sure nothing is blocking.
Regards
Luis
Hi all it is connected to the wifi network through the wifi adapter dont have any network printer, can anyone recommend a service engineer for ge ultrasound machine, i am from northern mew jersey
the system freez during exam or after 2 mintes this problem is common with voluson S serie i recomend replace the RFI board and our problem will be solved
Thanks a lot US specialist it freezes during an exam and sometimes when its on standby mode it freezes too
i will have someone change the rfi board
i am from new jerseycan anyone recommend an engineer who can do it for me thanks
MedWrench does work as the link between you and a service company. Browse service companies for your equipment or fill out a REQUEST FORM and we will help find a service company for you!
