Wrong Cassette Remove and Press + The RIS information could not be retrieved {Ref.MESS75}
Did you try to run a diagnostics?. Then you will be able to see what is failing. If you would like, I can help you with this diagnostics. Please send me an email and I will be happy to assist you.
Regards,
Luis
No, its fixed. Was such a simple problem. Dust was covering the optic reader. It could not read the silver dot on the cassette. Just cleaned the dust and it was fine. Small optic sensor just as the cassette enters the input buffer
