rotational motor making scraping noise
I hope all is well. We can help you to fix this issue. It could be the HDD.
Regards,
Luis
How do we go about fixing it. done over phone or do I need to package and send off.
Roger
You can send me an email and then I can give you my number. My email is medtechsolutions20@gmail.com
Regards,
Luis
I would be glad to fix this issue on the forum. Went into diagostic mode all other motors and function works well. When i test the rotational motor, it start spinning then makes some noises then stop and gives me erroe message.
it looks like one of the sensors is damage. I recommend you to go to the service diagnostic and then it will show you the problem.
Regards,
Luis
I went in the service diagnostic screen and ran all the diagnostic for motors and sensors. Everything schecked out and motor ran fine. Except for the rotational motor diagnostic button. When i click on it, the motor ramps up but then make clunking scraping noise then motor stop and times out. could it be the motor inside the cylinder that has gone bad? Does anyone have a rotational motor for sale?
Thanks
Roger
I am having the same proble with Device Error 5. Loading Screen precess was stopped.
Any answers. Thank you.
Mike
