Knee motor error
RE: Bed Report Post
The limit switch is internal for the gatch actuator. Is there anything obstructing the down motion? Otherwise I would lean towards the actuator itself.
Even I am having a similar kind of issue, I have searched all over the internet and even have posted on number of threads on different forum, no solution seems to work. I am really frustrated, can anyone of you here help me resolve this issue, I am very much tired now.
Make sure the limit switch tray is not cracked or broken,
Then I would be to disconnect the knee gatch motor at the movable end, run the head section all the way down making sure the limit switches are correctly set so the head section has abit of movement and not pressed against the frame. Then adjust the shaft until it lines up with the mounting holes. Then test run the knee gatch to the full range.
