I am working on a STRYKER - S3 bed that is not steering well. The reason is because the brake cam on the foot end is lower than its original position, therefore it is blocking the wheel from moving properly. When engaging the brake, the brake cam on the foot end only moves a little bit further down. I have been told that this bed is bent and there's no way to repair it. So I though I would post a question here to see if anybody has come across this before, and if replacing the brake cam on the foot end will repair the issue.
Wed Sep 09 2020
Steering issue
Fri Feb 05 2021Reply from Pxsanche01
Hello where u able to fix the problem , I'm having similar issues where steering is not engaging ?
Fri Feb 05 2021Reply from Chris-CBET
if it's bent...is it really worth investing money in? you can take it to a frame shop and they can fix it, but it's cost prohibitive.
