When powering on the machine it is going direct to the ventilation screen (not standby) and says restart ventilator. Some of the buttons work, some don't. It won't let me go to standby. Powering on and off is not working also took out the batteries with it unplugged and off to see if that would "reset" it no success yet. Ideas? I do have a software card but not sure if it is the same one as the machine has, will that be a problem?
Tue Sep 15 2020
ServoI not starting properly,
Tue Sep 15 2020Reply from Ben C
Tue Sep 15 2020Reply from RTgal
So after leaving it to charge for a few hours it fired up. I think the problem was the battery was completely drained.
So solved my own problem.
Tue Sep 15 2020Reply from Denova Medical
The ventilator does not need batteries to power up. You have an intermittent problem. You should go into the service mode and check the error logs.
