issue in the colonoscope fujifilm model EC-530WL3
RE: Colonoscopes Report Post
I recommend inspecting the valve carefully and also ensuring there is a seal around it.
T.
TJ Lobato | MedWrench Guru
Dear Sir,
thanks for your repalyed me as soon, already i change the air/water valve with another new valve and the proble is the same.
Please, what can i do
The silver air/water nozzle t the distal end sounds like it is clogged or damaged. You should not attempt try to remove that yourself as it needs to be sealed properly to prevent the nozzle from coming out of the scope and into the patient. Also, if you pick at it you can puncture the air/water channel inside causing more extensive damage. Any reputable repair company should be able to replace that for you. Providing that is all that is wrong it should be a minor repair.
Lee Ann Purtell
Capital Medical Resources LLC
614-389-1334 office
614-657-7780 mobile
614-467-3923 fax
leeann.purtell@capitalmedicalresources.com
thanks sir,
when I removed the air/water valve and closed the hole by finger, the air exit from the air nozzle at the distal end. But if I put the air/water valve and stop the hole of the center of the air/water button with a finger, the air does not exit from the nozzle.
It sounds like there is a compromise somewhere. I agree with Lee Ann, the unit should be sent in. The air is going somewhere, more than likely someplace where it's not supposed to be. Additionally, the disinfection process between patients may not occurr as it should. Dirty scopes are a bad thing.
T.
Hello Qasem,
Please reply with all the information on the unit's ID tag:
Serial number -
Model number -
Year of manufacture -
PLUS
Nature of the problems:
Pictures if possible
Where are the units installed? Country & type of facility.
Regards, Michel.
Servicios Tecnicos CMB7
535 Canteval,
Ottawa, Canada
Mobile: 6138185321
