It is self testing without proceeding to booting normally.
Sat Sep 26 2020
Booting problem
Sun Sep 27 2020Reply from Luis_Med
I hope all is well. Did you try to turn off and then turn on?. Did you get any error messages?
Regards,
Luis
Tue Mar 09 2021Reply from M&M
I have a 288C5 error at startup, before even starting movements.
Anyone can help?
MikeM
Tue Mar 09 2021Reply from Luis_Med
We can check the error in the manual. When are you available to work together?. It looks a hardware problem.
Regards,
Luis
Thu Mar 11 2021Reply from M&M
Thu Mar 11 2021Reply from Luis_Med
If I recommend you to upgrade the software of the CR, and then test it. If it does not work, we can read the logs and see what ks causing rhis problem.
Regards,
Luis
