Hi. Can this pcb be repaired ? How can I replace the damaged holder? Kind regards. Jaee
Tue Oct 06 2020
Coin cel holder broken.
Tue Oct 06 2020Reply from jroberts
If you're handy with a soldering iron/heat gun you could replace the coin cell holder yourself, unfortunately I do not have a direct source for the part, however a digi-key scan for coin cell holder (and specifying the mounting type, through-hole or otherwise) migth be a good place to look!
-J
Tue Oct 06 2020Reply from ReNew14
The coin cell holder was put on with a machine and we've had no luck soldering one back on, the solder will not hold.
Stryker will not work on the LP 20. they will however work on the LP 20e, which is basically the same thing with an upgraded battery.
