PM checklist
Hello, The service manual is located under the documents section on the left side of the web page. Preventative Maintenance is covered in section 3.
Hello Linda,
You need: - Preventative Maintenance Kit (12 months) 801-0631-00084-00
Also:
3.2 Periodical Maintenance Consumable Parts Kits Consumable parts are available in the periodical maintenance kits listed below:
• Periodic maintenance kit (12 month), P/N: 801-0631-00084-00
• A3 Periodic maintenance kit (36 months), P/N: 121-001072-00
• A5 Periodic maintenance kit (36 months), P/N: 121-001061-00
The checklist:
3.6 List of Periodic Maintenance Parts to be Replaced and Checked The following table lists the parts to be checked or replaced periodically inside the consumable parts kits. The replacement date starts from the date when the machine is assembled. The filter (part number:082-000423-00) is not needed for FDA A3/A5. No. Consumable Part Amount 12 Month 36 Month Part Number 1 Lithium-ion battery 2 (A5) 1 (A3) Check Replace 115-018012-00 2 Cell battery Lithium 3V35mAh D12.5*2.0 (for main control board) 1 Check Replace M05-010R03--- 3 Bellows assembly 1 Check Replace 0601-30-78968 4 O-ring (for airway pressure gauge) 1 Check Replace 082-000653-00(Old) 082-001524-00(New) 5 O-ring 15.54X2.62 (for bag arm) 2 Check Replace 082-000673-00 6 Gasket, bellows canister base 1 Replace Replace 049-000243-00 7 O-ring 15.54X2.62 (for O2 cell cover) 1 Replace Replace 082-000673-00 8 O-ring 14X2.65 (for Vaporizer mount) 6 Replace Replace 082-000934-00*** 9 AGSS filter 1 Clean Replace 082-000506-00 10 O-ring 8.5X2 (for rotating block of breathing circuit) 2 Check Replace 082-000665-00 11 O-ring 4.7X1.8 (for rotating block of breathing circuit) 4 Check Replace 082-000667-00 12 O-ring 16X2 (for rotating block of breathing circuit) 2 Check Replace M6M-010058--- 13 O-ring 27X1.5 (for Check valve dome) 2 Replace Replace 082-000626-00(Old) 082-001501-00(New) 14 O-ring 20X1.5 (for Check valve) 2 Replace Replace 082-000628-00(Old) 082-001503-00(New) 15 O-ring 6X1 (for Auto/Manual ventilation switch) 2 Check Check 082-000669-00 16 O-ring 23.47X2.95 (for Water Collection Cup) 1 Replace Replace 082-000629-00(Old) 082-001504-00(New) 17 CO2 Absorber Hose 1 Check Replace 049-000146-00 A5/A3™ Service Manual 046-001141-00 3 - 5 Periodic Maintenance List of Periodic Maintenance Parts to be Replaced and Checked The locations of the O-rings / Gaskets are shown in FIGURE 3-1. 18 Gasket, absorber canister exterior 1 Check Replace 049-000143-00 19 Gasket, absorber canister interior 1 Check Replace 049-000145-00 20 Gasket, CO2 bypass assembly 1 Check Replace 049-000142-00* 21 Seal, valve port (for CO2 Bypass shaft) 4 Check Check 049-000140-00 22 O-ring 23.47X2.95 (for CO2 Bypass Assembly) 2 Check Replace 082-000629-00(Old) 082-001504-00(New) 23 O-ring 4.47X1.78 (for CO2 Bypass shaft) 8 Check Check 082-000679-00 24 Tank Washer 3 Replace Replace 0348-00-0185 25 O-Ring 52X2 Auto/Manual ventilation switch 1 Check Check 082-001505-00 26 O-Ring 40X2.2 Auto/Manual ventilation switch 2 Check Check 082-001520-00 27 O-Ring 30X2 bag arm base 1 Check Check 082-001499-00 28 O-Ring 8.5X2.0 O2 cell port 1 Check Replace 082-000654-00(Old) 082-001525-00(New) 29 Inspiratory Flow Sensor 1 Check Check 801-0631-00060-00 30 Expiratory Flow Sensor 1 Check Check 801-0631-00056-00 31 O-ring 18X2.5 Breathing system base 2 Check Check 049-000813-00 32 Bellow check valve membrane 1 Check Replace 049-000240-00** 33 O-Ring 20.29X2.62 Bellows base 1 Check Check 082-001508-00 34 O-Ring 29.82X2.62 APL valve 1 Check Check 082-001515-00 35 O-Ring 25X2 APL valve 1 Check Check 082-001500-00 36 Dust filter 1 Check Replace 045-000241-00 37 O-ring, 20.35X1.78 FKM A70 1 Check Check 082-000676-00 / Touch screen 1 Check Replace 801-0631-00014-00 *The gasket comes with extensions on the barbed nibs with are there for as an installation help. The extensions need to be cut off after the gasket has been installed. **The gasket comes without the metal weight. The metal weight needs to be transferred from the previous gasket. ***The 6 O-Rings are for the 3 vaporizer option. Units with the 2 Vaporizer mount will only require 4 of the 6 ORings.
If you need a better looking list, email me.
Regards, Michel.
Servicios Tecnicos CMB7
535 Canteval,
Ottawa, Canada
Mobile: 6138185321
