AGFA CR10 X NX Viewer doesn't open
I hope all is well. What error are you getting?. You might need to reload the sofware.
Regards,
Luis
Hi Luis, so I got some pictures from the technician. The monitor looks weird, so I had to replace it with a new one. I'm not sure if you need a QHD monitor or something more than HD for the program to function properly.
I already reinstalled windows.
Is this possible without an NX installer?
What windows did you install?. Did you try to reinstall the nx viewer?. If you would like, you can sen me an email to coordinate to work together. My email is medtechsolutions20@gmail.com.
Regards,
Luis
We appreciate your participation and hope that the MedWrench forums will help you to solve your medical equipment issue
