NIBP Not Showing On Monitor
Can you expand on what you are seeing? Is the monitor displaying an error or inop message, or is it just not displaying a numeric? Is the correct size cuff being used? Is there a leak (usually indicated when the monitor will continue to pump and not reach set pressure level)? Is the hose kinked? Is the correct profile selected (Adult/Pediatric/Neonate)?
If the pump keeps running, it's a wrong size NIBP cuff. If the pump doesn't click or start, most likely it's a bad NIBP Pump.
Hope this help
USOC Medical
If the pump keeps running, it's a wrong size NIBP Cuff. If the pump doesn't click or start, then most likely it's a bad NIBP Pump.
Hope this helps
USOC Medical
