Hello. I unplugged the blanket warmer for a moment , replugged it back in, and it is no longer powering up. No lights, no response when pressing and holding the power button. Model #5624
Wed Oct 28 2020
Not turning back on after unplugging.
Fri Oct 30 2020Reply from Chris S
The only service manual i have is a hard copy, but here is essentially the troubleshooting flow chart:
- Is the power cord securely plugged in?
- Power to the unit at input Terminal Block?
- Check fuse on Power Supply PCB
- Check/Calibrate power supply 5V
- If calibration is successful, replace PC board. If unsuccessful, replace Power Supply.
