Bennett HFQ 300 x-ray unit - what would cause either fuse F1 (1.5A) or Resistor R32 (2 Ohm) on the charger board (A11) to blow.
Mon Nov 16 2020
Source charger pcb - A11
Fri Nov 20 2020Reply from AJ6969
Wed Nov 25 2020Reply from NevilleT
The batteries appear to be good and the fuses, both the negative or the positive side, seem to blow after or during an exposure
Wed Nov 25 2020Reply from DDA64
I would contact Don Mcfate at Xtech 417-753-9184. He has parts and will give you tech support to help you find the problem. I have worked with him many times!!!
