I had to replace the steel belt between the subscan unit and the counter-balance weight. The new belt is slipping, sometimes. I have greased the bearings on the subscan carriage and cleaned the steel belt with alcohol. I can move the unit freely by hand and there is no resistance anywhere. But, sometimes during initialization, the belt slips. The motor is still turning, but the subscan unit stalls before it reaches the HP sensor. Cleaning the belt with alcohol helps, but I have not been able to eliminate the problem. Any ideas how to fix this?
Thank you
Mon Nov 23 2020
Subscan belt slipping
Tue Dec 29 2020Reply from bio medical eng
