1) What is the weight of the Spacelabs SL3800?
2) Does the Spacelabs SL3800 have a VESA pattern on the back and what is the measurement?
Wed Dec 02 2020
Specification
Thu Dec 03 2020Reply from Chris S
Specs of the 94266 flat panel display (other options may be used)
75 mm M4 VESA mount
100 mm M4 VESA mount
100 mm M5 threaded holes on base bottom for table top security*
Pedestal base (purchased separately, p/n 010-1835-00)
Weight (approximately) With pedestal: 8.5 kg (19.47 lbs)
Without pedestal: 6.2 kg (13.67 lbs)
Specs for the monitor hardware
Monitor
Assembled weight 9.7 pounds (4.4 kg)
Dimensions 10.25 (H) × 6.0 (W) × 9.5 (D) inches (26.7 × 15.2 × 24.1 cm)
DC Power Supply
Assembled weight 1.8 pounds (0.8 kg)
Dimensions 1.65 (H) × 3.05 (W) × 5.04 (D) inches (4.30 × 7.94 × 13.13 cm)
Thu Dec 03 2020Reply from Integrity Biomedical Services
