Tue Dec 15 2020
Machine specifications for shimadzu mobile daRt evolutiont
Hello, I need machine specifications information for shimadzu mobile daRt evolution, such as rectification,control console type, tube insert type, peek tube voltage, maximum quality charge, condenser capacitance, filtration inherent and added, timer, collimation. thank you
Tue Dec 15 2020Reply from krkenney88
krkenney88
Hello ffredy4u,
Much of this information can be found by following the links to the documents section for htis item:
https://www.medwrench.com/documents/equipment/4515/shimadzu-mobiledart-evolution
However, I see that no actual spec sheet is listed there (although the manuals we already uploaded have technical data). I will upload the spec sheet, as well.
Koby Kenney
MedWrench Guru
Tue Dec 15 2020Reply from Ben C
Ben C
Thank you Koby! The spec sheet has been uploaded HERE
