Tue Dec 15 2020
Error aquilion 16
error aquilion insufficient space in the raw data storage area
   RE: CT Scanner Report Post
Tue Dec 15 2020Reply from krkenney88
krkenney88
Hi brildji,
When, or under what circumstances, are you encountering this error?
Koby Kenney
MedWrench Guru
Tue Dec 15 2020Reply from ADE123
The way Raw Data deleted is First In First Out FIFO configuration. If this is a setup issue then you'll have to manually delete the raw data images. But if this is something new (never had an issue it) then you might want to try initializing the Raw Data File on both Scan and Displah PCs assuming there is an issue with the E Drive/SCSI in the PC.
Best of luck!
Best of luck!
Wed Dec 16 2020Reply from brildji
Thank you for your answer how to initialize the raw data file
hello, from the acquisition
Mon Feb 05 2024Reply from Abo alez1
Hello everyone
I have a problem with Toshiba aquilion 16,
"This exam Plan cannot be executed. Insufficient space in the raw data storage area."
can anyone help.
