battery work around
I just wanted to mention that it's also a big issue on the bigger cousin monitors, the MP5SC, the Spot Check.. we put in 20 new batteries about 16 months ago and almost all of them are now saying that due to the number of cycles the battery is extremely aged and should be replaced.. and I've had charging issues with the factory batteries in the MP5SCs as well. And Philips' response is buy new batteries. Oy.
it's not the device, it's the battery itself.
Is your battery not holding a charge anymore?
have you run battery diagnostics under system diagnostics menu?
There might be a battery reconditioner out there, like what Zoll and ge have.
how are you at 300 charging cycles already? is that staff running the battery completley down before plugging it back in? or are they just running around plugging and unplugging it?
