Hi Please help with the resetting lamp hour after lammp replace. thanks you very much for sending the advice.
Kindly Regards
Fri Dec 18 2020
Lamp Hour
Tue Dec 22 2020Reply from Chris S
An EEPROM chip mounted on the lamp module tracks lamp life. I suspect you have to buy the lamp direct from the OEM to get the light to reset. I haven't worked on this specific model, but that's how it works in similar light sources. 3rd party lamps will operate but the life indicator will not reset.
