After boot up two beep and not working
Tue Dec 22 2020
Boot up problem
Tue Dec 22 2020Reply from T-Lobato
The service manual does not address anything regarding beeps. It says on page 38 to check fuses and the low voltage supply circuitry. I think that's a good start. I would also disconnect everything to see if that remedies it (if you have not already) as well as an electrical safety test.
Good luck!
T.
TJ Lobato | MedWrench Guru
Sun Jan 03 2021Reply from Ravindra
Troubleshooting code 12 in bipolar window . In service manual it shows microprocessor communication failure.
Please help me to find out error.
Thanks
