I just got a few of these machines and wondering if anyone knows how to change the default parameter. ie - every time you turn on Starting FiO2 is 100, set to program Ti instead of I-E, alarms start wider. Is thier a secret programming mode? These were rolled out quickly due to covid and the Rep has not come for biomed traning yet, not sure if he will soon as they have been rolled out across 20 sites and we were an after thought.
Thu Dec 24 2020
Change Defualt programming
Thu Jul 07 2022Reply from RPGa133
Hi. Did you get your issue solved? I have the same problem. Want a different startup configuration. Thanks.
Thu Jul 07 2022Reply from RTgal
Never got it solved. there is a way you can do create a custom setting but thats as close as I got.
