Date Time issue 2021
Hello, this is the procedure I have to change the date & time.
Toshiba Nemio SSA-550A:
Press PRESET D on console
Select PRESET on screen
Select TIME CORRECTION on screen
Change Time or Date
Click OK, then click EXIT
Hello Mr.Munawer Ali, I have the same issue with my Nemio 20 , 30 and XG all at the same time. Can you please elaborate the procedure to me. I would be very thankful to you.
Email:ahsanfazal76@gmail.com
Mob# +92-306-2569869
Can someone help me to set and get S/D ratio value in setting? Because i have to divide values by myself to get S/D ratio... RI and PI comes automatically but not S/D
Hi MarioLM I tried this procedure but the date after 2020 is not going to save. The date save only which is under the year 2020 not above the year 2020. Once date is set of the year 2021 but after restart it jumps to year 2000. If I set date to the year 2020 it is not jumpe to the year 2000 after restart..
Hi all, you may want to inquire with Toshiba about this, maybe the Nemio was not expected to last past 2020 and needs a software upgrade or it might be a date bug (try entering 2022 or greater). We no longer have our Nemio, so I can't test it myself.
Good luck all
Can it be BIOS cell problem?? That company put cell for 10-20 years life which expire on 31-12-2020 so everytime we need to re-enter the date
I doubt very much that it is due to the Bios cell, it would be very difficult to have it die exactly on Jan. 01, 2021 on all units. Plus if you enter an older date like 2019 or 2020 it keeps it, so that should rule out the battery.
Yes, your point is valid, my wrong thinking. Wish someone solve the problem soon, otherwise have to re-enter new dat each time when starting machine
