Every so often there is water dripping off the clean side control panel. I know the water is dripping from the HEPA filter assembly above the panel. The HEPA filter and prefilter is dry. The condensation system is working. I have replaced all the worn plastic pieces that might be spraying water in the direction of the vent. The blower is turning in the correct direction. There is no leaking fluid tubing over it. It doesn't do it on every cycle ran or on a specific cycle.
My question is, How is the water getting in the HEPA assembly filter if air is drawn through it from the outside?
All the checks mentioned above were recommended by Steris Tech Support.
