Philips Brilliance 16 ct
RE: CT Scanner Report Post
you need to make sure all com's are working . If your getting the gooey to close re-stop. Most likely one of these are not working.
Thank you, I check everything and I don't have any ideas more.When I try CPM Reset, Rotor and Tilt board don't wants to reset
Thank you, I check everything and I don't have any ideas more.When I try Reset, Rotor and Tilt board don't wants to reset
That's normal you might make sure the acs has a number on it. I believe it should be an 8, mot sure about the number
The number on ACS is not 8, maybe is 1 or 2, I am not sure.Is it maybe the problem because I moved couch horizontal by hands.What is your sugestion, maybe to reset encoders on couch or somthing else.
Thank you for your time
