Mon Jan 25 2021
Repeat scans
Using a GE Lightspeed scanner. If you need to repeat an exam for example a patient moved would this be set up as a new scan series under a new patient ID? Would each repeat have its own dose report? Or would it be logged as the same series and dose report? Would all of it be saved for total radiation in one or individually? Thank you
   RE: CT Scanner Report Post
