What is flow rate and required volume for DI water rinse cycle?
Tue Jan 26 2021
Water Usage
Tue Jan 26 2021Reply from Chris35
The manual states "Distilled (Purified) Water (Optional): 1/2" CPVC Male Slip (15-50 psi); 100-120*F (38-49*C)"
Neither pressure nor temp of pure water are monitored by the machine. It is only used for the final spray / flush if selected in the cycle. It is also basically rendered useless if the operator leaves "empty" flush hoses plugged into the manifold as the water will perfer the path of least resistance. Just FYI... We use DI tanks that supply about 20psi dynamic at around 70-75*F with no problems.
