Wed Jan 27 2021
Digitizer
I have a problem with it as it stays in constant red light and does not read the CAST and it appears in the screen of error number 10767 Plllzzz help me, and sorry for my English
Wed Jan 27 2021Reply from Luis_Med
I hope all is well. Did you try to reboot your reader?. Do you get any error messages?.
Regards,
Luis
I policies. I  just noticed that error. If we check the error, its pointing that  optical is dirty. Do you have the manual?. If no, please let me know and I can send it to you.
Regards,
Luis
Wed Jan 27 2021Reply from Ben C
Ben C
Manuals for this equipment can also be found HERE
Thu Jan 28 2021Reply from Ssmassm
Hello and thank u
This is my problem
https://i.imgur.com/1jG2EkY.jpg
And the Light is a fixed red no change
Thu Jan 28 2021Reply from AgfaDoog
AgfaDoog
You should check your CR's software version first. There's a TSB regarding that error.
"...Hello, IT... Have you tried forcing an unexpected reboot?..."
The IT Crowd
Check my LinkedIn profile for more info: https://www.linkedin.com/in/aacch/?locale=en_US
Available to move, looking for a job overseas full time :)
Sat Apr 24 2021Reply from Slobodan.Zivojinovic
Test scan failed: Not all CAL sensors detected --> defect or IP in digitizer
It is not a too big problem, just need some cleaning if you have luck.
Usually, there is dust from the sponge around the light cover under the optic module, and after some years sponge starts becoming dust, so if you do not know what I am talking about, it is better to call service.
If you need more info slobodan.zivojinovic@gmail.com
Good luck.
