Thu Jan 28 2021
Avance S5 system failure
Hi guys, after changing the gas mixer board the machine starts only to a screen showing " System Failure" and continuous alarming from the screen alarm and from the power control board. Any help is highly appreciated! Thanks on advance
Fri Jan 29 2021Reply from Cbracci
Did you reload the software
Fri Jan 29 2021Reply from todd128
what cbracci said anytime you replace a board you have to reload software.
and don't replace more then 3 boards at a time.
Fri Jan 29 2021Reply from VeoY
Ooo! I did'n know that.
First of all can you send me instructions how to do this and second if PCMCIA card is needed can I get it from somwhere as we don't have official GE tehnical reps.
Many thanks again!
you might try calling GE and see if you can buy the software, it should be v8.0, that is what ours is.
and yes it is on a PCMICA card.
there is a door on the left side of the monitor that is where the card goes, have the machine off put the card in and then turn the machine on it will boot to that card and you just slect down load software. if it ask selct all, it takes about 15 minutes to down load the software.
Mon Feb 01 2021Reply from VeoY
Many thanks, guys!
Now I just need to find from where I can by this card with software, as it's not available localy. Any suggestions are welcome.
Have a nice week to all of you!
Hi again!
Can some of you give me the part/article number of this PCMCIA Service Application card?
In general do you have a list of part numbers for this system?
Many thanks again!
