The workstation can't connect to read the cassette. It says there is an 11950 error that has to do with the IIP address. We initially changed the IP settings on the computer so that we can create a shared folder to read the files from a laptop and the workstation lost the connection. After we reverted the settings to the initial ones the error was not corrected and connectivity is lost. Any help will be appreciated.
Fri Jan 29 2021
Error 11950
Fri Jan 29 2021Reply from Luis_Med
Fri Jan 29 2021Reply from Dinos
The error means that you lose connection with the console while you insert the cassette. Do you have the manual?.
Regards,
Luis
I can send you this manual and we can work together. What is your email?.
Regards,
Luis
Wed Jun 30 2021Reply from Sampane
Hi bro can you please send me the manuel service of the cr-ir 359 thank you so much nasurauzuchino@gmail.com
Tue Oct 17 2023Reply from mustafakreedan
